I am looking at the EGR system from a cost reduction point of view and therefore not an expert in this field.
As I understand/see there is a vacuum unit on the engine which is connected by 2 plastic pipes to a solenoid unit. The solenoid is mounted in a vertical postion on the inner wing. There is an outlet at the top with no other connection to it and I presume is for measuring the external air pressure and it looks as though it is mounted vertical for a reason (I think).
I would like to mount this solenoid in another postion and at a different angle. Would this be possible?
