Elastomer closed cell insulation for heat conservation
engrom
Materials
Jul 31, 2003
92
Peers,
Can anyone pls advise on the closed cell elastomer insulation for heat conservation below 120deg C? It is industry practice to use mineral/rock wool, cellular glass for heat conservation, but not really sure about the limitation of elastomeric material as HC insulation on gas process piping. Since the temp range > 90 -150deg C is quite critical to avoid CUI, I expect there are some previous industry experience on using this material.
Cheers
I know they use the strong type of styrofoam with alu. sheeting.
Sometimes wooden blocks as supporting when You need a fixed support.
Thanks Steve... Do you know where can I get a copy of CINI Handbook for download (free or paid)?
You might try googling CINI Insulation Handbook.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
