Electrical steel and wirecutting
123Cat
67
Good Morning
Yes as the title
If I manufacture a stator will that wirecut surface degrade my electrical quality
Thank you
Solid or laminated?
Wire EDM or abrasive?
All the lamination's are stacked together , welded on the edge ( it welds nice , I guess its the high silicon )
Then the stator is edm wirecut out of the centre of the stack
Thank you
Got it straight in my head now
No carbon ,,, no hardening
No punching ,, no work hardening taking place
Just a thin oxidised surface , quite thin ,, no effects
But if the recast metal on edges causes the lams to have electrical continuity with each other then your rotor losses will be higher. The lams are supposed to be insulated from each other.
We never welded, we always used the rotor bars as 'rivets' to hold it together.
I know all of the responses so far must be guesses, because the problem statement is incomprehensible.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Thanks very much Ed Stainless
The stacking and and wire cutting operation is to get the stator shape
I then seperate all the laminations and restack them all with insulation between each one
and wind copper wire around them
There is just about zero carbon in the steel
So I assume the edm wire cut operation does not change any steel characteristic , electrically wise
No it doesn't change anything as the damage is very shallow. Some people us an light abrasive to remove many edge buts that might form from the cutting, but as long as you are not being overly aggressive they should be fairly smooth.
