Electricity from trees?
Petroleum
Jun 25, 2001
3,412
Plugged in: Startup hopes to tap electricity from trees
“Lagadonis said tests have generated 0.8 volts to 1.2 volts by driving an aluminum roofing nail half an inch into a tree attached to a copper water pipe driven 7 inches into the ground. But the electricity is useless because it's unstable and fluctuates.”
e=2
Greg: if you managed to use the home itself as the cold reservoir for the steam engine, I guess you'd get the 1-.38 kW too. But a COP of 7 is pretty optimistic- it presumes a better quality heat reservoir for the heat pump to draw from than most of us have at hand. You would need to drill a lot of expensive wells to provide access to the only decent source at hand to most of us- the earth itself- to obtain such a favourable COP.
