huangdf118
- Feb 26, 2017
- 11
I am working on a project to install pump/driver trip systems on about 350 pumps based on measurement of high pump vibration. The one pump in question for me has a steam turbine driver (which prevents us from simply splicing into the motor start/stop switch to stop the pump as I am doing with most others in the project). The steam turbine is old enough that the manufacturer does not have a low-cost readily-available solution – their offered solution was overly complex and very expensive. Therefore, we felt that it would be more cost-effective to engineer our own.
Our little joint side-job in this larger project is to devise a simple system which accepts an electrical signal from the pre-engineered “to-be-installed” vibration detection module, and mechanically pulls on the external trip-lever of the steam-turbine. We can likely make use of one of several available options of electro-mechanical solenoid, so it may just be as simple as designing a suitable mounting bracket.
My puzzling is how to devise a simple system, your suggestions would be appreciated.
Thanks,
Thanks,
