RVSWA
- Jul 13, 2003
- 97
As a practice, we "electronically" stamp our drawings with the following process. I have asked a number of other professionals and so far very little has been said. I'm considering talking to the board but thought I would stop here first. My question to you, in your opinion do you feel we meet the requirements of our State? (Washington Administrative Code provide below )
1) we have an 8.5x11 sheet with a number of blank seals printed on it.
2) to "seal" a document, we identify the documents being sealed, sign, date, hand write the expiration date, and finally include our job number.
3) we then scan this page to PDF where it is cut and pasted into the model space of our Autocad file. On each page a viewport displays the signed stamp.
4) we keep a copy of all of our signed seals for future verification.
5) as a policy we never release a "working" Autocad drawing, instead we wblock the information requested, never including a signed stamp. If a revision takes place after the release of drawings, the drawing file is saved with a new revision date in the file name. The old stamp would then be replaced for the next issuance of drawings.
6) our final document is usually a PDF which is either printed and/or provided on disk.
Your thoughts please.
WAC Chapter 196-23-070
Signature.
The terms "signature or signed," as used in chapter 18.43 RCW and/or Title 196 WAC, shall mean the following:
(1) A handwritten identification that represents the act of putting one's name on a document to attest to its validity. The handwritten identification must be:
(a) Original and written by hand;
(b) Permanently affixed to the document(s) being certified;
(c) Applied to the document by the identified licensee[;][.]
(d) Placed directly over the seal/stamp of the licensee.
(2) A digital identification that is an electronic authentication process attached to or logically associated with an electronic document. The digital identification must be:
(a) Unique to the licensee using it;
(b) Capable of independent verification;
(c) Under the exclusive control of the licensee using it;
(d) Linked to a document in such a manner that the digital identification is invalidated if any data in the document is changed.
Signature.
