cat977
Geotechnical
- Jan 23, 2013
- 3
We ran into a problem while installing a ADA ramp. We installed a ADA ramp per the “boiler plate” details given on the plan. The only grades shown was a spot elevation at the detectable warning surface and at the old / new sidewalk transition about 20lf away.
The top of the ramp which was installed per the detail rises to an elevation 2 ½” higher than the existing sidewalk and then a slopes about 10lf. to the existing elevation. The problem is the customer and architect contend that we should have changed the elevation high point to meet the existing elevation without the slope. It is our argument that if there was to be a grade change the architect needed to show it by note or elevations shown on the plan. We all know why the architect isn't backing us up!Is there any writings to back up my argument?
Thanks,
Excavator.
Thanks,
Excavator.
