JT-1995
- Sep 26, 2022
- 36
I am looking to design a horizontal embed flush with the top of my concrete footing at a tight elevation tolerance. The load on the future column that will be field welded to the embed is small, particularly in the shear and uplift. But the elevation is something I want to make as easy as possible for the contractor to hold. In past details (constructability and holding an elevation was an afterthought) I have simply seen designed nelson studs on the embed plate and away you go. Today I started a search for info on embed anchor design and specifically weldable rebar as the connection to the concrete. That search revealed clearance distances from the embed anchor to the reinforcement. I did not know that existed BTW, we always tied the rebar to the nelson studs (why not??). What I would like to do is bend a couple lengths of reinforcement into something approximating a "rebar standee" and tie the 2-3 lengths of rebar to the footing top and bottom rebar to help hold an elevation during the pour. In my mind the contractor could adjust the flair on the "legs" of the standee to make adjustments in the elevation until it was within tolerance and then tie it off. My questions are:
- does tieing the rebar embed to the footing rebar violate the ACI and IBC embed/rebar clearance requirements?
- I have found some prescriptive language that the weld between the weldable rebar and the bottom of the steel embed should be 'an all around 7/16" fillet weld', although I can not find a detailed discussion of describing the basis of this remark. Is this a code description? For my situation that weld would be extreme, can someone confirm that it is sufficient to simply design the weld as any other eccentrically loaded weld to determine its throat and length?
Thanks for your thoughts in advance.
