I want to encapsulate a electrical winding to use in salt water....but i don´t know the kind of composite or resin i´ll need, could somebody help me, cause this is not my thing... i was worried about, the diference on the thermal exparsion, about cracking...cause stator is for class F isolation, and close to the windings is posible there´s hot spots....
Then, other question is about compatibility with the isolation used on the windings, i mean, is posible to use a composite that is good electrical isolation, and good for the use in salt water.... cause the motor will work submerged onto the sea.... somebody tell me about use DER 330 (Dow Plastics) that is an liquid epoxy resin...what do you think...
thanks in advance.
thanks in advance.
