not2fast
- May 19, 2007
- 20
- 0
- 0
I have a small Heat bench that I put together to test a few small M/C Radiators, at the moment its set up to suck air through the Radiator. I'm measuring the Depression with a water manometer between the Fan and the Rad for each test... e.g. lets say its 20mm H2O @ 8m/sec
Now if I change the setup so the fan is Blowing with the same given positive pressure @ 20mm will the velocity and Air Flow be the same or slightly different ?
any thoughts...
not2fast
any thoughts...
not2fast
