Engine seizure
Green 123
Aerospace
Feb 19, 2024
57
High pressure rotor of turbofan engine was found to have seized during third start attempt subsequent to two hot start. do you have any idea on causes of the event?
OK, so "Hot Start" seems to be when the temperature during starting rises faster than it should leading to either automatic shutdown or controlled shutdown when the pilot notices the temperature reading.
Google seem to think this is one of
Fuel system fault putting too much fuel in
Low battery / start speed not putting enough air in
Facing the engine into the wind
Very hot day.
But basically cooking your engine is going to lead to bad things happening
Ta muchly
blade rub due to rotor too slow or not spinning during start/warm
hot spot/spots during full start
or
too fast full start
or multi injector clogged creating hot/cold spots
Yeo
Very hot day.
Yep thus what I was trying to explain and fail to get through.. you did a little better job.
Op
Now the forensics has to start.
A tear down is required and every detail
Has to be meticulous photographing, and inspection of every detail., and failed components to be submitted to a met lap.
However contact the manufacture if it is under warranty. Even if it is not I would highly recommend they do the tear down and inspection.
Green 123...
These 'definition' questions of Yours can easily be answered by simple research. The definition/implications of 'hot start' is/are easy to find on-line.
We are not here to play games with You.
