need some help whit jetpulse engine blueprints. 2
benjamin20006
3
Hello guys, didnt know where to put this, but assume this is the place as it is aircraft related. but as said.
i wish to make an Jetpulse engine, similare or like the Argus jetpulse engine, and woundered if any of you guys could help me out whit blueprints and maybe step by step, like blueprints for bouth small and a large one so i atleast can start of whit a small one, the reason tho as i ask about this is as i have been diging around the internett, but all the blueprints was either really blury or hard to understand,
wish to have detailied blueprints for the fuel system, valve, combustion chamber and etc in cm and mm. so if any of you could help me out i would be really happy and thankful.
The Argus jetpulse [sic] engine was used on the V-1 bombs. Seems like an odd thing to build.
More typical is the dynajet pulse jet engine - uses a simple valve. Dang. Just looked at the prices for those. I should have invested in a bunch and kept them on a shelf.
The current king of pulse jets is Robert Maddox, aka Rocketman. See
In addition to some amazing projects he sells kits and fully assembled engines Amazingly his prices for ready to run engines** aren't all that much higher than collectible dynajet units, but they look to be about 100X more powerful.
**still need the fuel delivery system but I expect Robert Maddox will supply info on that as well.
Yeah the reasons for a Argus jet pulse is because of its simplicity. I only need the lenght and forms of it so i could make it myself:) its for a summerproject
The term is pulse jet.
Sorry to burst your bubble, but if someone works for a company that makes them, they aren't going to just give you a design for free. And if they're capable of designing one - which is non-trivial - they aren't going to do that for free, either.
Plan sets are available from Maddox for purchase. Don't blow yourself up.
If you look at his site you also see the tail pipes glowing red.....
Also have you looked at this lot?
Yeah i try'd to respond earlyer. But using my phone is a litle more challenging. I am at least as said out to find out what i should think about whit this engine and fuel system
