Hello!!
I was wondering if i might be able to get some help/advice on this query I have. I have an excel spreadsheet which calculates the enthalpy change and heat required when chnaging the pressure of a gas sample in a gas pipeline. However I am unable to fully understand where some of the figures are being taken from:
This is the formula that appears to be being used to calculate the enthalpy of the gas coming in:
H= [(c-E1)*Tin]+[D(Tin^2)]+[(A-E2)*P1]-[B*P1/(Tin^2)]
Where:
Tin = Temp. of the gas entering
Pin= Pressure of the gas entering
A= -0.00792078
B= 950.85
C= 0.0314566
D= 0.000009138
E1= 0.000358
E2= 0.001391
There is also a figure called ERF (which I presume is some type of correction factor) which is added to the enthalpy, this is calculated by:
ERF=E3*(P1^2)+(E4*P1*Tin)+(E5*Tin*P1^2)+E6
Where:
E3= 0.0003572
E4= 0.000008397
E5= 0.00000119
E6= 0.0845
the Change in enthalpy is found by taking the total enthalpy (including correction factor) of the gas leaving the pressure changer from that of the gas entering the pressure changer.
I cannot understand what the values A,B,C,D, E1 ...... etc. are. They are simply numbers in the spreadsheet I have been given.
Any help or advice on where they might have come from would be much appreciated - Sorry for the long post!
Aisers
