Equivalent horizontal force to dropping Tank
DaveHolder
80
I’m doing design for a steel barrier to prevent 2.5 tonnes cylinder tank 5 meter hight and 2 m Dia from tipping over! I’m not sure what is the equivalent horizontal force to 2.5 tonnes vertical load? Is it 2.5 tonnes x sin ()?
What force is causing it to tip over? Wind, seismic, sloshing etc? I assume the force you want to know is the one that causes the tipping to occur. You also need to know where that force is acting.
In case accidentally the tank falls over! I think to take he moment around tipping point to work out pushing force either working out tipping angle then the force could be Mg sin tipping angle?
Are you trying to find the force required to tip it over, or the force due to the impact when it tips over? or both?
