ERROR: Couldn't find ABAQUSLM running on "server"
nilesh_dot
IN
Dear helpers
I would greatly appreciate your help in resolving this issue.
I am having this problem when I try to run verify commands such as abaqus verify -user_std to verify that I have linked Fortran to ABAQUS correctly. However, I get the following error and I am not sure what is causing this to happen. Please let me know if you have any suggestions.
This error appears whenever I run to verify for example abaqus -user_std or abaqus verify -all or abaqus verify -std. What should I do if the issue is related to firewall?
Note: There is no issue when I run an Abaqus job without subroutine.
yes, i have gone through the link but unable to resolve the problem.
first try
C:\temp>-NoLicenseCheck command to abaqus verify
'-NoLicenseCheck' is not recognized as an internal or external command,
operable program or batch file.
second try
C:\temp>abaqus licensing ru
lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
Flexible License Manager status on Sat 10/12/2024 13:01
[Detecting lmgrd processes...]
License server status: 27009@compute3
License file(s) on compute3: 27009@10.2.60.16:
lmgrd is not running: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
