Error Message "Unable to delete file"
JOJOMO
29
I'm running a contact analysis and came in this morning to this error:
Unable to delete file(s) C:
\DOCUME~1\ADMINI~1\LOCALS~1\Temp\Administrator_steel_sliding_12wc_friction_304.
Please check that you have file ownership and permissions for removal.
I'm running V6.6 on a 64 bit machine w/ xp.
Any suggestions?
I don't know that there's a problem until I get that error message and the job aborts.
John,
I have the similar problem before, with the same configs as you. You just need to re-run the job, it occurs once in the blue moon. Might be the problem of 64 bit.
