Vidaman
- Jul 28, 2002
- 39
Hello All,
Pardon the intrusion from an ME here, but my company is currently working on a specialized solenoid valve controller that will packaged in a plastic case with aluminum front and rear panels. The front panel will be covered by a polyester membrane keypad. The product is powered by an external 24VDC power supply. The question that has been asked is how this product will handle ESD. Appart from standard CE, type testing, what are the concerns with such a product with regard to ESD? We would like to sell this into the semicon automation industry and I would like to understand that industry's concerns. Clearly, without a direct tie to ground, the enclosure and its inards will be floating, but your typical Keyence panel mount pressure display or Watlow heater controllers are packaged in plastic enclosures. They do not appear to have any special modifications that I can see.
Thoughts?
Thanks,
Mike
Thoughts?
Thanks,
Mike
