SteelAndSteel
- Aug 13, 2013
- 23
Two beams one 60x60 and another 60x60 beam with a welded 8 mm sheet shall be placed inside a 500mm long 140x70x4 beam, see the attached picture. The material for all beams is S355J2H. I wonder if it will be a good fit. When I am checking the tolerances (EN 10210), I can see a scenario where it doesn't work, but I don't think it is probable. What do you guys think?
