I'm looking to find errors in my assumptions/methodology.
I'm currently trying to model a pump system in simulink. The system involves a centifugal pump, pressure tank (sff a tee from the main line, and outlet. Currently I'm using the pressure difference between pump discharge and the tank branch to determine flow between the pump and the tee to which the tank is connected. I'm likewise doing the same for the pressure difference between the tee an the outlet, with outlet pressure discharge to the atmosphere.
I'm using dQ/dt=1/I * (P - RQ^2 - Ph) to develop the flow based on P, the pressure difference. Ph is pressure drop due to static head, RQ^2 would be presure drop due to frictional resistances, and I would be the fluid inertia, I=rho*Length/Cross Sectional Area.
Knowing these two flows, I can then solve for the flow into the tank branch to determine (based on precharge ,tank volume, and initial water pressure stored) the pressure at the tee, so that I can go back and solve everything else.
My goal is to find the "pressure at the outlet," since the overall aim will be to keep the system output at a constant pressure.
What I've been doing is this: after I know the flow out of the system, to then use that flow to determine the pressure drop that does not include the exit loss. However, this always seems too low, since the exit loss is minor compared with the friction loss from teh straight pipe, and minor losses of other fittings.
Also, such a high pressure difference (50 psig in tank, 0 psig at outlet) causes such a high flow that the tank invariably bottoms out in the simulation. Also, with the methods described below, the "outlet pressure" ends up negative (3/4 inch diameter piping).
Since I'm in electrical engineering, I figure that my relative lack of experience in these is causing me to overlook something. Any suggestions as to where I may be going wrong?
