export to DXF
MerK55
8
I am using UG NX 3, just converting over. But when I export to dxf it translates the center lines, dimensions and curves but it does not translate the model. I tried moving everything in the drawing into the same layer but for some reason I cannot get the model to show up.
Where I am at we are stil on NX2, But this should work with NX3.
1. file export CGM.
2. Creat a new part and import the CGM.
3. Then export to DXF.
Hope this helps...
Jeremy
thank you very much. I should have asked you earlier before messing around forever. I skipped NX2 and just started with NX3 but I miss the simplicity of NX 1. NX 3 just seems to want to do everything for you when it really shouldnt.
I appreciate your help.
