levey12
- Nov 20, 2009
- 3
I am an EIT working on a preliminary design for an exterior crane system. The crane bay is 80’ wide with rail beams that span 30’ and an approximate height of 25’. One side of the crane bay is supported by A-frame columns; however, the other side has obstructions, which forced me to consider different support options.
In the attached document you can see the proposed option. I have been questioning myself about how to distribute the forces to the column system. I initially designed the rail beam support column (col. 1) for all of the vertical wheel loads and then distributed the entire thrust force through the strong axis of the remaining column (col. 2), which resulted in a basic design for a cantilever beam. However, I know that the thrust force will induce moment in both columns. What moment should I design each column for? It is my understanding that less moment will be resisted by the rail beam support column (col. 1) due to its weak axis orientation and thus should be designed for less.
Also, when designing the braces to tie the columns together, they have to be able to resist the compression flange (prevent LTB) and thus decrease the unbraced length (I have been treating Col. 2 as a cantilever beam). Is it OK to design these for 2% of the compression flange force as you would for lateral stability bracing? Currently, I have been using AISC appendix 6 to design them as nodal column braces.
Any suggestions are appreciated.
Best Regards
Best Regards
