External pressure on an ellipsoidal head ASME VIII div 1 (UG-33-1b) 1
Raaden
89
I have run into a little problem. I am supposed to calculate a formed head of a semi ellipsoidal shape that is under a external pressure. This is my first time doing this calculation so this might be a really stupid question, but anyway: I have followed the steps and arrived in subpart 3 of ASME II, part D. My head is of A-387 22Cl.2 material, so I should look at Fig. CS-2. But when I look in the diagram I see only graphs for up to 900°F and my design temperature is 560°C (1040°F). Is there a way around this or am I missing something totaly obvious?
Pontus
You are not missing anything. You are simply not permitted to use that material at that temperature under any external pressure. You would need to generate a Code Case (with all the supporting documentation and calculations - of course) to extend Fig CS-2. That said, I would do a search through the Code Cases to see if someone has already done that for your material.
If that doesn't work, you have to choose a different material.
Thanks TGS4. Not the answer I was hoping for, but thanks anyway.
TGS4 is correct. Paragraph UG-20(c) states that you cannot exceed the maximum temperature limits shown on the external pressure charts.
Is it possible that you could use a lower design temperature for the external pressure case?
-Christine
Raaden-
TGS4's response is correct. Christine's solution may work for you. Often the external pressure requirement is accompanied by a different design temperature.
Do a search for Code Cases as TGS4 suggested. You may find something useful there.
Another option since your temperature is fairly close to the 900°F limit is to put a relatively thin refractory layer in the head - say 1" (25mm) or so. You'll have to run the calc's to determine the expected metal temperature, but I'd bet that 1" (of even a hard face, relatively high conductivity) refractory would work.
jt
