Extract special coordinates
AtomicNico
Nuclear
May 10, 2016
62
Hello, that's me again but for another question
I got some pipes where I need to extract some special coordinates.
I'm attaching a file to show what kind of pipes I have.
For the T, I need to extract the origin coordinates, the end coordinates and the branch coordinates.
For the other one, I would like to extract the intersection of the neutral fibers.
How can I make that?
Moreover, how can I extract the diameter?
Best regards
 http://files.engineering.com/getfile.aspx?folder=6fde1b02-f6bf-41b4-a89b-0d8be11d2271&file=coude-iso-3d-90-roule-soude-inox-304-l-316-5611-dmod1.jpg
I got a little problem with my loop: on multiple selections, I only got the 1st element selected which gives me the results but after I got an error "Coordinates: type non compatible", so either I've got a problem in my loop or the selection method is wrong.
Code:
Sub CATMain()
    Dim intNbEdges As Integer
    Dim doc, sel, spa, ref, measurable
    Dim inputObjectType(0)
    Dim i As Integer
    Set doc = CATIA.ActiveDocument
    Set sel = doc.selection
    Set spa = doc.GetWorkbench("SPAWorkbench")
    'Selection of circular edge
    inputObjectType(0) = "TriDimFeatEdge"
    Status = sel.SelectElement3(inputObjectType, "Select the edge", True, CATMultiSelTriggWhenUserValidatesSelection, True)
    If (Status = "cancel") Then Exit Sub
  intNbEdges = sel.Count
  For i = 1 To intNbEdges
  Set ref = sel.Item(i).Reference
  Set measurable = spa.GetMeasurable(ref)
    Dim Coordinates(2)
    measurable.GetCenter Coordinates
    Dim Radius As Long
    Radius = measurable.Radius
    MsgBox "x = " & Coordinates(0) & " ; y = " & Coordinates(1) & " ; z = " & Coordinates(2) & " ; radius = " & Radius
    Next
End Sub
Moreover: the selection palette is useful but it doesn't take the TriDimFeatEdge with the selection palette. How can I make it automatically?
I thought about a objGCATIASelection0.Search "(CATLndSearch.TriDimFeatEdge),all" but it doesn't seem to work
do you actually select a circular edge (planar)?
Eric N.
Yes, the inputObjectType(0) = "TriDimFeatEdge" only allows me to select circular edges, I tried it on several models.
I presume the error is in the loop but where is the question... Do I need to reinitialize one of the variables? Like coordinates?
i was able to select not planar edge with your code. I had problem only if I selected an edge that was not a circle.
Eric N.
this s where you can use on error resume next / on error goto 0
Eric N.
But when I select all the edges of my part one at a time, there won't be any problem, and on this part I'm sure all I have are circular edges (start and end of a pipe).
If I put a "on error goto 0", I will have to make a new selection, right?
the on error goto 0 is here to cancel on error resume next.
so when you have something like an edge curve and want the circle center. you know circle center will fail if edge curve is not a circle so you do:
Code:
for i = 1 to x
    create center point of edge (assuming it's a circle)
    if err.level <>0 then edge is not circle  but system continue (resume next)
    if err.level = 0 then point is created = edge is circle
    on error goto 0   ' this will bring err.level to 0 and stop script if any error is found = back to normal behavior.
next
Eric N.
Yes! It works! Thanks Eric!
For the selection, do you have an idea about why the edges are not selected by the Tools Palette? I can't find anything about it on internet.
Also, I tried to automatize it, making a selection by the edges, but the command I tried (sel.Search "(CATLndSearch.TriDimFeatEdge),all" ) does not work that way. Do you have an idea about it?
The macro makes a selection of the part, then find all the edges and extract the wanted datas of all edges
I'm still stuck on my problem of edges so I have to ask again, but in a better way:
Does anyone knows what are the items selected by the tools palette when you make
Code:
Status = sel.SelectElement3(inputObjectType, "Select the edge", True, CATMultiSelTriggWhenUserValidatesSelection, False)
Because I can select the edges when I click on it but it's not included in the selection trap.
Same type of question with the command
Code:
sel.Search "(CATLndSearch.Product),all"
How can I replace the .Product in a way that includes the edges? .TriDimFeatEdge doesn't seem to be good.
I'm sorry to ask here again but I can't find those informations in the automation doc nor on the web
I tried a new way to do it but it failed, maybe you can tell me where is the error.
I tried "sel.Search("Type=TriDimFeatEdge, all")" but Method Search failed. So I wanted to add TriDimFeatEdge as a new support of search.
In automation it says that Add method will take an AnyObject, but when I wrote CATIA.ActiveDocument.Selection.Add(TriDimFeatEdge), still not working.
Do I have to put some line before? I know it's this hierarchy: AnyObject => Reference => Boundary => Edge => TriDimFeatEdge
Ok, I found how to do it:
- Selection of all the edges with sel.Search "Topology.CGMEdge,all"
- Selection of only the TriDimFeatEdge
Hey guys, likely the last time I'm asking you something but I need a little help again
Here is my loop to select the edges, that works alone
Code:
Sub CATMain()
    Dim i As Integer
    Set sel = doc.Selection
    MsgBox intNbEdges
        Set myCircle = sel.Item(i)
        If myCircle.Type = "TriDimFeatEdge" Then
             On Error Resume Next
             Dim Coordinates(2)
             Dim Radius As Long
             On Error Goto 0
             MsgBox "x = " & Coordinates(0) & Chr(10) & "y = " & Coordinates(1) & Chr(10) & "z = " & Coordinates(2) & Chr(10) & "Diametre = " & 2 * Radius
             Err.Clear
    End If
    Next
End Sub
And I've got my first macro that will select the pieces, which is this one:
Code:
 '//---------- Get current selection & root product
  Set objGCATIASelection1 = objGCATIADocument0.Selection
  Set objGCATIAProduct1 = objGCATIADocument0.Product
  If objGCATIASelection1.Count = 0 Then
    objGCATIASelection1.Search "(CATLndSearch.Product),all"
  End If
  Err.Clear
  Dim objProduct As Product
  Dim objProductMat As Product
  Dim intNbParts As Integer
  Dim k As Integer
  intNbParts = objGCATIASelection1.Count
  For k = 1 To intNbParts
    Set objProduct = Nothing
    Set objProductMat = Nothing
    Set objProduct = objGCATIASelection1.Item(k).Value
    Set objProductMat = objGCATIASelection1.Item(k)
    Err.Clear
    Dim objInertia As Inertia
    'On Error Resume Next
    Set objInertia = objProduct.GetTechnologicalObject("Inertia")
    Dim getMass As String
    getMass = objInertia.Mass
    Dim partName As String
    partName = objProduct.Name
    Dim Mat As Material
    Dim oManager As MaterialManager
    Set oManager = objProductMat.Item(k).GetItem("CATMatManagerVBExt")
    oManager.GetMaterialOnPart objProductMat.ReferenceProduct.Parent.Part,Mat
    matName = Mat.Name
    'MsgBox matName
    Dim Coordinates(2)
    objInertia.GetCOGPosition Coordinates
      intGReportCurrentRow = intGReportCurrentRow + 1
      InsertAnEXCELRowAt (intGReportCurrentRow)
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleMass, getMass
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitlePartName, partName
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleMaterial, matName
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleCOGX, Coordinates(0) & "mm"
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleCOGY, Coordinates(1) & "mm"
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleCOGZ, Coordinates(2) & "mm"
    Next
But when I put the 1st one into the 2nd one, I don't succeed:
Code:
Sub CATMain()
  Dim objProduct As Part
  Dim objProductMat As Part
  Dim i As Integer
    Dim j As Integer
  StartCATIA
  If Err.Number <> 0 Then
    Exit Sub
  End If
  StartEXCEL
    Exit Sub
  End If
  Set objGCATIASelection0 = objGCATIADocument0.Selection
  Set objGCATIAProduct0 = objGCATIADocument0.Product
  If objGCATIASelection0.Count = 0 Then
    objGCATIASelection0.Search "(CATLndSearch.Part),all"
  End If
  intNbParts = objGCATIASelection0.Count
  For i = 1 To intNbParts
    Set objProduct = objGCATIASelection0.Item(i).Value
    Set objProductMat = objGCATIASelection0.Item(i)
    Err.Clear
    'Dim Mat As Material
    'Dim oManager As MaterialManager
    'Set oManager = objProductMat.GetItem("CATMatManagerVBExt")
    'oManager.GetMaterialOnPart objProductMat.ReferenceProduct.Parent.Part,Mat
    'matName = Mat.Name
    Dim Coordinates(2)
    Set sel = CATIA.ActiveDocument.Item(i)
'// Now for the second loop
MsgBox intNbEdges
    For j = 1 To intNbEdges
        Set myCircle = sel.Item(j)
             Set ref = sel.Item(j).Reference
             Dim oCoordinates(2)
             measurable.GetCenter oCoordinates
             Dim Radius As Long
             MsgBox "x = " & oCoordinates(0) & Chr(10) & "y = " & oCoordinates(1) & Chr(10) & "z = " & oCoordinates(2) & Chr(10) & "Diametre = " & 2 * Radius
             Err.Clear
    End If
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleDepX, oCoordinates(0) & "mm"
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleDepY, oCoordinates(1) & "mm"
      WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleDepZ, oCoordinates(2) & "mm"
    Next
      'WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleDepX, oCoordinates(0) & "mm"
      'WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleDepY, oCoordinates(1) & "mm"
      'WriteToEXCELRunSheet intGReportCurrentRow, strGReportTitleDepZ, oCoordinates(2) & "mm"
Next
End Sub '/////////////////////////////////////////////////////////// CATMain
I'm guessing it's about the selection "sel" which is likely wrong because the MsgBox intNbEdges shows up empty.
