extrusion on curved sheet/surface 3
I hope you aren't planning to model the bumps of a diamond plate sheet.
Are You ?
Tomas
exactly i want do this, you are right toost. pls give me solution.
Don't model the diamond pattern. That would be a waste of time and only serve to make your model heavier and more difficult to work with. Call out the material on your drawing and/or use a hatch pattern on the drawing views for a pictorial reference.
www.nxjournaling.com
What Cowski said.
Occasionally we have to model cross hatching in order to machine it into our molds. It's a pretty awful experience. NX slows to an absolute crawl.
