I have been told if you By-Pass some air around the avaporator coil, you will dehumidify the air while not needing to reheat it.
What is more, the fact that you reduce the air flow through the evaporator coil, you reduce the suction pressure of the cold gas, thereby reducing the evaporating temperature of the coil. Therefor the dew point is lowered and you wring out that much more moisture out of the air. It is claimed you can get the evap temp down to 35*F by starving some some air flow by By-Passing it.
Finally when the By-Pass air is mixed with the Dehimidified air, the result is much drier air that is nonetheless warm, and usually does not need to be reheated before supplying to the space.
Does anybody have any experience with this they would like to share ?
Thank you in advance.
