Facts, Myths, and Givens in Anthropogenic Climate Change (ACC) 36
zdas04
I have been repeatedly accused of refusing to accept the basic "facts" of Anthropogenic Cimate Change (ACC nee AGW, nee Global Warming, nee Global cooling). I think we really need to define terms.
In the following I'm going to rely heavily on The Shattered Greenhouse: How Simple Physics Demolishes the "Greenhouse Effect". I've linked the article in for anyone who wants to check my interpretation of the story. It has an extensive bibliography at the end for further reading.
Greenhouse Effect
The basic idea of a greenhouse gas comes from Arrhenius' in 1896 representing (some say misrepresenting) the work of Fourier from 1827
Arrhenius (1896 said:
"Fourier maintained that the atmosphere acts like the glass of a hothouse, because it lets through the light rays of the sun but retains the dark rays from the ground."
In other words, visible light can traverse the atmosphere more easily than infrared can traverse the atmosphere back into space. Fourier actually said nothing of the kind, but it has entered our collective culture that he did.
This idea ignores the fact that in greenhouses, the glass acts to prevent the heated air from mixing with the ambient air outside the box (i.e., prevents mass transfer) and has nothing to do with different wave lengths of light. The ACC concept says that the heating is due to energy absorption and disregards the fact that hot gases rise and there is no physical barrier to how far they can rise.
The linked article ends with:
Consulting Geologist said:
In the real physics of thermodynamics, the measurable thermodynamic properties of common atmospheric gases predict little if any influence on temperature by carbon dioxide concentration and this prediction is confirmed by the inconsistency of temperature and carbon dioxide concentrations in the geological record. Moreover, when the backradiation "Greenhouse Effect" hypothesis of Arrhenius is put to a real, physical, material test, such as the Wood Experiment, there is no sign of it because the "Greenhouse Effect" simply does not exist. This is why the "Greenhouse Effect" is excluded from modern physics textbooks and why Arrhenius' theory of ice ages was so politely forgotten. It is exclusively the "Greenhouse Effect" due to carbon dioxide produced by industry that is used to underpin the claim that humans are changing the climate and causing global warming. However, without the "Greenhouse Effect", how can anyone honestly describe global warming as "anthropogenic"?
If the thermodynamic underpinning of the "Greenhouse Effect" is absolutely missing, ACC does not have a leg to stand on.
Carbon Dating
Much has been made about the "fact" that atmospheric CO2 must have come from geologically old sources because of the lack of Carbon-14 in the atmospheric CO2. The idea of carbon dating is the result of very creative work in 1946 by Willard Libby at the University of Chicago. His concept is that Nitrogen-14 in the atmosphere is bombarded by solar radiation and that some proportion of the impacts will cause the stable nitrogen to lose a neutron and become radioactive Carbon-14 (radiocarbon). He further postulated that the number of collisions is relatively constant and that as animals breathed the C14 a portion of it would be absorbed into their systems and decay to Carbon 12 over time. This means that as long as the animal is breathing they will be ingesting C14. When the animal stops breathing they will stop ingesting C14 and the inventory of radiocarbon in their bodies will decay with a half life of 5730 years. So if you find a sample with 1/4 as much C14 as you expect then it is something like 11,460 years old. There are a large number of assumptions that go into this calculation, and many of them are invalid for any given biological sample, and the uncertainty in dating cam be millennia.
The big question is what sources of fuel have zero C14? Of course hydrocarbons that haven't been alive for 300 million years likely have zero C14. Same with CO2 from volcanoes. What about biological material that has been frozen under the permafrost since the last ice age (2.58 to 0.012 million years ago)? That stuff has been through a lot of half lives of C14. So if the climate is warming, and if the permafrost is retreating, then biological action on the newly thawed material would have zero C14. This means that C14-free CO2 in the atmosphere does not necessarily have to come from industrial activity.
Temperature Record
The temperature record is not just one thing.
[ul]
[li]Data from 2005 might be from digital instruments that self-report or from satellite surrogates.[/li]
[li]Data from 1970 likely comes from analog instruments manually recorded[/li]
[li]Data from 1900 likely comes from spotty coverage at universities and on ships.[/li]
[li]Data from 1800 comes from ice cores, sea floor samples, and tree ring analysis[/li]
[li]Data from thousands of years ago to about 1.5 million years ago come from ice cores[/li]
[li]Data older than that comes from analysis of the fossil record (i.e., what kind of plants were growing? how big were they?)[/li]
[/ul]
We have no way to directly measure temperature. We can't do it today. We couldn't do it 100,000 million years ago. We can measure the impact of a given temperature on a material with very good accuracy and repeatability and very low uncertainty. That mercury thermometer that your mum stuck up your bum didn't measure your temperature, it measured the thermal expansion of the mercury in a constrained channel. All temperature data is the result of an evaluation of the impact on something physical to a temperature change. To turn ice core data into temperatures the scientist melts the ice then boils the water in a tightly controlled space and evaluates the gasses that come out of the sample. A computer model is used to convert the mix of gases into a temperature. These models are very clever and quite involved. If you assume that CO2 forces temperature change, you get one set of temperature numbers. If you assume that changes in CO2 are a result of temperature change you get a very different set of temperature numbers. When people plot CO2 concentration on the same graph as "temperature" data they are being purposely misleading since everyone with the ability to run this calculation knows that they have selected "cause" or "effect" before they generated the temperature numbers and in spite of having different scales they are actually the same number.
The oldest data has a temporal uncertainty of no less than ±10,000 years. The Ice core data is probably ±200 years. Data from the 1800's is certainly ±1-2 years. Data from the early 1900's is around ±6 months. More contemporary data has a better temporal uncertainty.
Contemporary data is collected from thousands of weather stations and stored in a database. The database (actually there are several, each its own format) contains one record per station per time period. No indication that the data is anything but true and accurate like scientific data is supposed to be. It is anything but that. "Everyone" understands that temperature on a blacktop surface is higher than temperature on a grassy field. As urban populations have expanded to formerly rural spaces, many weather stations have shifted from rural to urban. If you look at the data for the station, there is a step change in the output. To be able to compare a station that is currently urban to data from when it was rural, requires some "adjustments". These adjustments are done destructively without even a flag in the database. Also many of the stations have been broken for months or years and just receive "estimates", without any explicit definition of the estimating technique.
Finally, the historical record can be modified. Luckily several "outsiders" made copies of the databases at various times. Comparing those copies to the "official" records indicates some distinct trends. Several warm periods from the past are no longer included in the historical record. Data from 2000, show the 1930's to have been as much as 5°F warmer than the current string of "warmest on record years". Many of those record-breaking years were warmer by less than 0.05°F when the contemporary records have an uncertainty of ±0.1°F, but "Warmest Year on Record" gets headlines.
Impact of Climate Change
The list of things that ACC is going to cause has been widely published. It includes wildfires, more hurricanes, more tornadoes, floods, droughts, more deserts, reduced biodiversity, rising sea level, etc. This list was generated by a group of grad students sitting around a table throwing out ideas. Things like "when it is hotter it feels like the desert, I bet deserts will grow". In fact the geological record shows that in general during a warm epoch there is additional moisture in the atmosphere and deserts shrink--this is happening today all over the world. The list of consequences is not part of the "science" of ACC, but the scientists involved have rarely spoken out against the list. The scientific theories of ACC talk about physical reactions, but they can't even predict clouds or rotating systems let alone wildfires.
Consensus
Before you say you "believe" in ACC remember:
Belief is the acceptance of a theory in the absence of data
For every Michael Mann there is a Judith Curry. For every Al Gore there is a Jim Imhoff (U.S. Senator from Oklahoma). For every David Suzuki there is a Lord Monkton. For every Bill Nye there is a Jack-in-the-Box Clown. For every IPCC report there are contributors who claim their statements were misrepresented. The 97% consensus was made up from whole cloth. Before this subject got so political and began having so much money thrown at it, there were frank and honest discussions among the scientific community and people of varying views could get published or get on the podium at conferences. Not today. There are a large number of scientists who have actually lost tenure for holding opinions that the ACC story does not hold up to scrutiny, and getting published with papers outside the mainstream is nearly impossible. Not the "science" of my youth.
[bold]David Simpson, PE[/bold]
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
Nobody “calls themselves a skeptic.” Only “believers” paint others with identities. One’s “cause for concern” is not license to confiscate the product of others through means of force i.e. taxes and regulations. Of course looters and moochers do not care to abide by “rules” that protect individuals. Instead they will say, their actions are necessary for the sake of humanity, the world, the children, the unborn, the nonexistent... anybody but the individual whose wealth they are confiscating.
The physics by which CO2 concentration rises after a rise in global temperature due to, say, Milankovich cycles or other known climate drivers is pretty easy to understand: rising surface temperatures would cause CO2 to desorb from the oceans, melt permafrost etc.
That's not what is happening this time, though.
How do we know? The isotopic balance of the CO2 in the atmosphere demonstrates that the new CO2 is of fossil origin, and it accounts for only about 1/2 of the fossil CO2 we know we've emitted by burning fossils- the rest has ended up in the biosphere and the oceans.
That the CO2 concentration in the atmosphere lagged global mean temperature in past does not in any way negate the fact that adding CO2 to the atmosphere narrows the radiative wavelength window into outer space, which obviously represents climactic forcing, i.e. shifting the balance to retaining heat.
Furthermore, we're at a level of CO2 in the atmosphere that hasn't been seen on earth for at least 800,000 years- before anything close to an identifiable human existed.
MoltenMetal -
Thank you for that contribution about variations of isotopes in atmospheric carbon. That's something that is easily understandable (at least by me) and that (assuming it's true) demonstrates with some degree of certainty that a good portion of the current increase in C02 in our atmosphere is due to fossil fuels.
Jdmunno -
For what it's worth, I consider myself a skeptic. Personally I try to be skeptical of both sides of most issues. I try not to take a definitive stance on the far side of an issue unless I have really spent a lot of time understanding both sides. Now, the challenge for me (and for most skeptics) is to avoid "confirmation bias" where I overly skeptical of information opposed to my position and much less skeptical of information that supports my position.
I'm just pointing out that I don't think anyone referring to someone who doesn't buy into the global warming as a "skeptic" is not intended as an insult. I think it's just an accurate descriptions. Just as I have referred to some on the other side of the issue as "global warming alarmists". It's an accurate term, not an insult. They're alarmed by what's happening and they are trying to sound the alarm for the rest of us.
While "global warming alarmists" might technically not be pejorative, it's clearly been used by the other side as a means of painting their antagonists as "Chicken Littles" running around screaming that the sky is falling, etc. It's pretty clear that it's an ad hominem attack, to paint the opponents as hysterical, or as conspiracists, or as money-grubbing sluts willing to say anything for money, while they are merely reasonable "skeptics."
Regardless, the data should speak for itself, and continuing to claim that "this" proves "that," when the current data clearly disproves it, is simply an attack of attrition, rather than logic. If temperature ALWAYS leads CO2 rise, and we have a CO2 rise, then temperature must already be high, and so global warming is happening. Moreover, given that the current CO2 levels are more than 50% above the historical highs used in the argument, then our temperature rise is in uncharted territory, and THAT should be cause for reflection, both in terms of what is actually happening, and whether one's position as a "skeptic" is simply trying to deny reality.
I see both denial and anger, so we're only two more steps from acceptance. Unfortunately, we humans are rarely able to move cleanly to acceptance; we know we're supposed to eat right and exercise, yet, we're getting fatter every year, so perhaps we're all "fat skeptics," read that any way you want ;-)
TTFN (ta ta for now)
Whilst totally agreeing with IRstuff on how the word "alarmist" is currently used, I think Josh makes a good point. If a skeptical review of all the available evidence leads to alarming conclusions, then we should be alarmists.
I have therefore decided I will sign up for membership of the small but growing group of Climate Change Skeptic Alarmists.
And yes, the term "skeptic" is a compliment, not derogatory at all.
Doug Jenkins
Interactive Design Services
All scientist should be skeptics. Being a scientist does not require any certificate. It is someone who practices the scientific method. The fundamental principle of the scientific method is that nothing (i.e., no hypothesis) can be proved to be true with 100% certainty, but one example of a hypothesis not being true, disproves the hypothesis 100%. So scientists do not (or should not) design experiments to prove a hypothesis, but to try to prove it is wrong. When many experiments designed to disprove the hypothesis are unsuccessful, the hypothesis become a theory that is believed to be true. In this context the word "belief" is used to mean this is what we think is true, but it may still be wrong. This is very different than religious belief, which mean something we accept on faith.
I do not think that alarmist is a pejorative. It is a description of a type of behavior. The alarmist might be right (Louis Pasteur) or wrong (Chicken Little). Alarmism has has nothing to do with science per se, but it may be a reaction to scientific discoveries.
"But there is one feature I notice that is generally missing in Cargo Cult Science. That is the idea that we all hope you have learned in studying science in school—we never explicitly say what this is, but just hope that you catch on by all the examples of scientific investigation. It is interesting, therefore, to bring it out now and speak of it explicitly. It’s a kind of scientific integrity, a principle of scientific thought that corresponds to a kind of utter honesty—a kind of leaning over backwards. For example, if you’re doing an experiment, you should report everything that you think might make it invalid—not only what you think is right about it: other causes that could possibly explain your results; and things you thought of that you’ve eliminated by some other experiment, and how they worked—to make sure the other fellow can tell they have been eliminated."
The absence of published critique of their own work is what dooms climate change scienciness.
Cheers
Greg Locock
[red]This terminates this lengthy thread. Please start NEW threads in this forum if you wish. Thank you.[/red]
