Hi
I got 4 x Condenser water pumps in parallel....2 new and 2 old.... non return valves on each
Occasionally I loose condenser water flow through the chiller when running of the new pumps
I did notice water flow noise coming from the two old the condenser water pumps, when they were off off. It was a hissing noise as if there was flow. The fan on the motor was not turning as I thought it would if the non return was not functioning. Anyway I closed the discharge valves on each of the old pumps and the hissing sound immediately stopped.
My question is; can water run backwards through the pump with out the impeller necessarily rotating if the non return is not sitting right?
BQ
BQ
