MechEngineerNT
- Dec 13, 2013
- 25
Hey Guys,
I'm running a quasi-static non-linear FEA in Ansys trying to simulate crimping a primer into the cartridge using a die crimp tool. In short, the crimping operation works in real life (80 units tested), to which I've decided to try to simulate. However, the results of the simulation aren't matching up with the real life results. I've put in all the right material properties of a 7075-T6 aluminum, and have also put in the bi-linear curve to simulate strain hardening. In the attachment, you can see I'm above the ultimate strength of the material with von mises equivalent stress criterion, although it is in compression. Why does it work in real life, but the simulation isn't showing it? This has been giving me hell!
Thanks!
Thanks!
