Student BE
Bioengineer
many people advise to do hand calculations in order to verify FEA results at least approximately. Some even say that they always do these hand calculations. However, I Wonder how it is possible to do such calculations. I know that in static solid mechanics constructions can be simplified to basic elements: beams, bars, frames, trusses, plates, curved beams etc. But it's only possible in case of fairly simple shapes.
Also in other fields (for example buckling, modal analysis) there are some equations that allow hand calculations for specific problems.
But how to do these calculations for example in fluid dynamics ? Even square channel flow would be hard to evaluate. I doubt anyone uses Navier-Stokes equations in such cases.
And as an example of something hard to verify with hand calculations (going back to static stress analysis) can you say how to calculate this (obly the way to do it, without any numbers of course):
or this:
and this:
P.S. From what I know it's not possible to use FEM in hand calculations of anything more complicated than simple bar or couple of beams so I guess it's not the way people do it.
or this:
and this:
