I'm trying to analyze a weldment with Femap Express. I have two questions:
1. I've been saving the weldment and a parasolid then re-importing it as a single part. Is there a way around this? Perhaps the full version of Femap? Does it let you analyze assemblies? If so, how much does that cost?
2. When I try to analyze the weldment as a single part, I have to use boolean operations to unite all the components but keep getting a zero-manifold thickness failure. Is there a way to make the welds have penetration so I can eliminate this problem?
