Will passivation or pickling remove ferrite from the surface layer of 316L stainless steel? I'm not talking about free iron contamination, but the actual ferrite as part of the grain structure of the metal.
I have a customer that I'm building a vessel for and the product is sensitive to ferrite levels above 5 FN. My base material is at 2-3 FN but the welds go up to 9-13 FN, even using special "low ferrite forming" weld rod gives me a 5-6 FN. Since I'm only worried about the exposed/wetted surface ferrite level, I was wondering whether passivation or pickling will lower this surface ferrite level.
