BrkfldEE
- Sep 22, 2009
- 25
I have a hydro generator that is 12.5MVA, 13.8KV. The rated field volts and amps are 250V, 240A; and according to my datasheet the field resistance is 0.904 ohms. The rotating exciter has nameplate info of: 80KW, 250V, 320A, shunt wound. I am removing a field breaker that is in the exciter field and installing a field breaker in the generator field. How do I figure the size of the field discharge resistor? My research so far tells me that it should be 1 to 1.5 times the field resistance, is that right? How do I determine the Watt rating?
