Fillet dim 3
ctopher
17,421
USA, CA
New one for me.
I added a dim R .50 to a corner. It passes near a tapped hole.
When I dimension the corner where it meets the tapped hole, it shows the following dimension:
If I select the fillet where it does not meet the tapped hole, it's a normal radius dimension.
Anyone seen this before? What does "RM R.50 x 1.0" mean?
(The position of the dim is for illustration here only)
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
I think you will find that RM signifies Mean Radius. It's possible that the fillet either breaks into, or is bisected by the tapped hole.
itrans,
Yes, it does. Interesting though, if I add the tapped hole after the fillet, it does not dim this way. SW sees the fillet break thru the hole after it has been filleted, not before.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
By adding the fillet after the hole, the fillet is probably propagating itself around the hole.
By adding the hole after the fillet, the hole is just cutting through the fillet ... no propagation.
RM .50 x1.0
RM = Mean Radius
I believe the [.50 x1.0] is the dimension of an obround - due to fillet bisecting and propagating around the hole, effectively becoming obround.
DPeyton,
That makes sense, but I can't anything on the feature that represents the "x1.0".
Maybe a slight bug with SW?
As I wrote earlier, it only happens one way and not the other.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
If you edit the dimension or look in the property window, do you see the variable name for the 'x1.0' ? Maybe that is a clue?
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
It shows as "RM<DIM>x1.0".
Interesting, if I right-click on the dim, then change it to a diameter dim, it changes it to "RMM 1.00x1.0".
The dim text still shows it as "RM<DIM>x1.0", but displays the "RMM...it will not go away. If change back to show as a radius it still shows RMM.
A bug I think.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
