Flange design with full face gasket
DK44
196
I am in need of guide lines on following.
1. Is design of welding neck flanges with full face gasket covered in ASME Sec VIII Div 1 or Div 2.
2. If not covered in the codes, how to design same.
3. Is such design acceptable for code construction.
Appendix 2 is specific to ring type gasket. But may ask why do you require a full face gasket?
Detailing is a hobby,
DK44, there is a design method based on Taylor Forge Bulletin #45.
I'd think most software would implement this...
Mike
Thank you SnTMan.
1. I understand that, for accurate, easy and firm location of gasket, full face gaskets of soft composition are used for low pressure applications.
2. Yes Taylor Forge Bulletin #45 gives the procedure.
3. PD 5500 also covers the design method.
4. But why ASME is not considering this deign into the code?
DK44
See Figure UG-34 sketch (p)
There are things in ASME and not in PD 5500
Dunno really, but the design is not as often used, and most software implements TF #45
1. No for VIII-1. (Assuming the full face gasket is used with flat faced flanges.)
2. U-2(g)(-c) using Taylor Forge Bulletin 45 and/or 502. Check with your AI to be sure that TF45/502 meets this code paragraph.
3. Yes, see #2 above
If this WNF will be bolted to a blind flange, see UG-34 and Fig. UG-34, sketch (p) for design requirements of such.
Phil
