ajk1
- Apr 22, 2011
- 1,791
Is there any flashing that is particularly resistant to corrosion from de-icing salts? The situation is a public library where the existing deteriorated flashing extends from ahout the 4th brick course above the sidewalk down to the sidewalk. We are removing the sidewalk, sounding the garage roof slab below to detect delaminations and repairing, re-waterproofing the garage roof slab, placing a high stength drainage board, then re-pouring the sidewalk and putting in new flashing to replace the existing deteriorated flashing. I am not sure that galvanized steel flashing would be as resistant to corrosion in the salt environment as would be wanted.
QUESTIONS
Is there a PVC flashing, or any other non-metallic flashing, that could be used?
If so, are there any disadvantages to it?
Does it come in brown colour?
Is it UV resistant?
How should it be specified (thickness, etc.)?
If a metal flashing is deemed to be corrosion resistant in a chloride environment, how should it be specified...how thick, etc?
QUESTIONS
Is it UV resistant?
