Flat Slab vs Conventional Beam Slab
shakeelahsan
21
0
0
Dear All,
For a high seismic activity zone, what frame system for a multi storey RCC building should be proposed.
Two options being;
1. Flat Slab supported directly on columns
2. Conventional Beam Slab supported on columns.
Recommendations requested.
Engr. Shakeel Ahsan
Director Engineering
CMEC - Pakistan
Could you please give a description of how the structure responses better with a conventional frame system than a flat slab?
Engr. Shakeel Ahsan
CMEC - Pakistan
I would say both would work favorably as long as you provide lateral force resisting system, say, concrete shear walls. Your choice may be driven by whether cost or aesthetics is critical. with flat-slab you have a flat ceiling finish as compared to exposed beam which may require additional ceiling.
I expect beam-column option could be cheaper.
My call was based on concern over crashing force due to stress reversal around columns. Stress redistribution is likely for beam-slab (also higher reserve capacity) systems rather than flat slab.
Beam systems if with moment frames may offer some seismic advatages, lower R. Otherwise flat plate with shearwalls generally will have cheaper forming cost.
There are several ACI documents and there are also papers related to flat slab connections to shear walls and columns. Some engineers will use the slab to resist seismic moments....kind of like connecting the shear wall to the exterior frame to load share (semi-dual system). It is up to you to decide wether you want to take the slab or slab/beam stiffness into account for the structural system...or merely use it as mass....different design philossphies that will have impact on the overall response. I would say envelope the cases.
Others have studied PT slabs and the ability to prevent crushing at column and shear wall interfaces.
Like anything else, you can always design and detail the connection.
In Terms of concrete systems, see ASCE 7-05. In California we use Concrete Moment Frames, Concrete Shear Walls, and Dual Systems. System selection depends on height, arch requirements, and what space is available for a seismic system etc... High rises lend themselves to dual systems....but some have designed with shear walls alone (tube structures). Pauley & Priestly have a good discussion on the topic of system selection.
Would that be a good idea to set different fc' for Columns and other structural members.
We have set fc' for columns at 3750 Psi and for raft, retaining walls, shear walls, beams and slabs at 3000 Psi.
How this helps increasing stiffness at joints?
It is prone to causing mistakes in design and construction. Except the floor slab, and non-structural walls, try to maintain consistent fc' to simplify the processes.
I dislike the use of flat slabs for lateral resistance in high seismic regions because there's no sensible way to provide shear resistance without relying on the concrete shear strength. That makes it tough to ensure a ductile flexural failure mode. Shear studs do help with this to some degree.
It's also very difficult to design flat slab / column joints such that they can sustain repeated, inelastic rotations without resulting in bond stress problems.
Why not to make a simple example for comparison. Say a 20'x20' one story building with 4 columns and 2' overhang each side. One with flat slab, the other with beam in between columns. A day's work, worth a lot.
