drago8
- Jun 26, 2015
- 41
Hello All,
Just to have a discussion regarding flat slab. What I understand of flat slab that it is supported by column instead of beams. So for the ground floor construction of flat slab, how is the arrangement of the reinforcement in flat slab? If there are perimeter beams around the flat slab, will the slab reinforcement still goes into the beams?
Furthermore, when I did a design for the flat slab at ground floor (but I ended up using solid slab instead) some told me that the slab reinforcement can be reduced as long as the ground is well compacted. They also said there is no need to worry much about the punching shear check from the column as the slab will lay on the ground. Only if the slab is at the first floor, or above, will it become critical.
Could someone explain this to me.
Thanks.
#LoveWins
Thanks.
#LoveWins
