Flattening a visco-elastic-plastic material (Abaqus)
Satiar
Hello members
I am modeling flattening of a ball using Abaqus. It consists of three steps: flattening (load control, static), creep (visco, constant load) and tangential loading (static, displacement). My 3D model converged for elastic(v=0.46)-viscoplastic (power-law) material and the results are good, but when I introduce yielding it doesn't converge in the second step (creep) and interrupted at very initial increments (<1.0E-6). I am validating my model with another model defined in Ansys so I can only use power law and elastic-plastic parameters. I am wondering what is the problem and should I used UMAT or VUMAT subroutines? or Can I use the default material properties of Abaqus? Can Abaqus handle creep and plastic deformation together?
Thank you in advance
Just to make sure, are you using hybrid elements?
Yes to be exact i use C3D8RH
Can you attach an input file of this analysis or at least describe the details of the simulation (loads, BCs and in this case especially material data) ? In case of convergence problems everything should be checked and we can't help without more details.
** MATERIALS
*Material, name=Deformable
*Creep
1.6036e-05, 2., -0.789
*Elastic
700., 0.46
*Plastic
14., 0.
14., 0.4
** INTERACTION PROPERTIES
*Surface Interaction, name=IntProp-1
1.,
*Friction, rough
*Surface Behavior, penalty
** BOUNDARY CONDITIONS
** Name: Bot Type: Symmetry/Antisymmetry/Encastre
*Boundary
Deformable-1.Bot, PINNED
** Name: Sym Type: Symmetry/Antisymmetry/Encastre
*Boundary
Deformable-1.Side, ZSYMM
** INTERACTIONS
** Interaction: Int-1
*Contact Pair, interaction=IntProp-1, type=SURFACE TO SURFACE
Deformable-1.Surf-1, Flat-1.Surf-1
** STEP: Step-1
*Step, name=Step-1, nlgeom=YES, inc=1000
*Static
0.0001, 1., 1e-08, 1.
** Name: RP Type: Displacement/Rotation
*Boundary
Flat-1.RP, 1, 1
Flat-1.RP, 3, 3
Flat-1.RP, 4, 4
Flat-1.RP, 5, 5
Flat-1.RP, 6, 6
** LOADS
** Name: Load-1 Type: Concentrated force
*Cload
Flat-1.RP, 2, -19.464
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
** STEP: Step-2
*Step, name=Step-2, nlgeom=YES, extrapolation=PARABOLIC, amplitude=RAMP, inc=10000
*Visco, cetol=1e-05
1e-05, 600., 1e-08, 600.
** OUTPUT REQUESTS
*End Step
** STEP: Step-3
*Step, name=Step-3, nlgeom=YES, inc=1000
*Static
*Boundary
Flat-1.RP, 1, 1, 2.
** OUTPUT REQUESTS
*End Step
