I have a simple sheet metal panel with one bend. I need a left and right style of this part so I've drawn one side with bend and then save a copy for the other side. I would like to flip the bend direction so it projects down instead of up but when I try to grab the bend and rotate 180 degrees with the wheel I get a face/face check failure. See the attached file.
