hausfxr
- Sep 2, 2021
- 4
I'm an architect doing work in my basement and am attempting to design a flitch beam using our existing 4x6 wood beams. We are removing the center posts of four beams which are spaced at 5' o.c. and are perpendicular to the existing 2x6 joists. The plan is to sandwich the beams between two C-channels. The ceiling is low so head room counts, but I don't want to cut into the joists with a recessed beam - I like the idea of the exposed C-channels. I'm attempting to use a 5" tall channel which will allow drywall will extend over their tops to create a clean look.
All steel and wood members will be fully supported at both ends.
Only one beam has excessive loads on it. The others have only the floor load and seem adequate with having each C-channel on either side of the wood beam supporting half the load. However, the one beam with roof loads fails with half the load and it's the only beam I'll design as a flitched beam. I've included the BeamChek calcs for that beam with 47% of the load applied, and, it would appear that with 6% of the load taken by the existing wood, it may be adequate.
Here's my question: When I do the proportional calcs for the combined beam, it appears they are more than adequate and contradicts the marginal calculation from the BeamChek calc. I'm hoping someone can let me know if I'm on the right track. The only examples I could find as a guide used steel plates and those seemed straightforward - I'm not sure if you can use the same simple method with a C-section.
