ugandabob
- Jul 27, 2006
- 27
In a multi-storey building, the diaphragm action will be provided by several horizontal trusses in each floor (the floor is grating).
Can this be modelled as a rigid diaphragm? When modelling the trusses individually, horizontal deflections are below 2 x story drift, although one level is close.
Changing to flexible will have a sizable impact on the forces in the braced frames, so I do not want to overdo it. Semi-rigid modelling not an option.
Thank you.
Thank you.
