Greetings Mechanikals,
I need some help in determining the flow through what I will call an “annular orifice”.
1. I have a smooth pipe with an inside diameter of 24 in.
2. Centered in that pipe is a thin plate with an outside diameter that is 0.08 in. smaller than the inside diameter of the pipe.
3. I know the pressure drop across the plate to be 0.5 psid.
4. The medium is water at 80 deg F.
What is the formula for calculating the flow through this annulus?
Thanks in advance,
Goosen
Thanks in advance,
Goosen
