font size with color 1
Durga Abishek
Aerospace
Jun 12, 2020
9
0
0
IN
please suggest changes in the macro that identifies dimensions and change colors with font and also this have to identity each letter
Option Explicit
Private Const OTHERCOLOR = "0, 0, 0"
Sub CATMain()
Dim txts As Collection
Set txts = getShowTxts()
If txts Is Nothing Then Exit Sub
Dim colorMap As Variant
colorMap = initColorMap()
Dim sizeDic As Object
Set sizeDic = groupBySize(txts)
Call execChangeColor(sizeDic, colorMap)
MsgBox "Done"
End Sub
Private Sub execChangeColor( _
ByVal group As Object, _
ByVal colorMap As Variant)
Dim sel As selection
Set sel = CATIA.ActiveDocument.selection
Dim vis As VisPropertySet
Set vis = sel.VisProperties
CATIA.HSOSynchronized = False
Dim key As Variant ' Long
Dim rgbAry As Variant
Dim rgbTxt As String
Dim dt As DrawingText
For Each key In group.keys
If UBound(colorMap) > key Then
'In colormap
rgbTxt = colorMap(key)
Else
'other
rgbTxt = OTHERCOLOR
End If
rgbAry = Split(rgbTxt, ",")
sel.Clear
For Each dt In group(key)
sel.Add dt
Next
Call vis.SetRealColor( _
CLng(rgbAry(0)), _
CLng(rgbAry(1)), _
CLng(rgbAry(2)), _
1)
Next
sel.Clear
CATIA.HSOSynchronized = True
End Sub
'return dic(txtsize,lst(drawtxt))
Private Function groupBySize( _
ByVal txts As Collection) _
As Object
Dim dic As Object
Set dic = initDic()
Dim prop As DrawingTextProperties
Dim key As Long
Dim lst As Collection
For Each dt In txts
Set prop = dt.TextProperties
key = CLng(prop.FONTSIZE)
If dic.Exists(key) Then
Call dic(key).Add(dt)
Else
Set lst = New Collection
lst.Add dt
Call dic.Add(key, lst)
End If
Next
Set groupBySize = dic
End Function
Private Function initDic() _
As Object
Set initDic = CreateObject("Scripting.Dictionary")
End Function
Private Function getShowTxts() _
As Collection
Set getShowTxts = Nothing
sel.Clear
sel.Search "CATDrwSearch.DrwText,all"
If sel.Count < 1 Then
MsgBox "Text not found"
Exit Function
End If
Dim i As Long
For i = 1 To sel.Count
lst.Add sel.Item2(i).value
Next
sel.Clear
Set getShowTxts = lst
End Function
'Sample that changes color with text size
'by kantoku
Option Explicit
Sub CATMain()
MsgBox "Done"
End Sub
'In colormap
Else
'other
rgbTxt = OTHERCOLOR
End If
sel.Clear
sel.Add dt
Next
CLng(rgbAry(0)), _
CLng(rgbAry(1)), _
CLng(rgbAry(2)), _
1)
Next
sel.Clear
End Sub
As Object
Dim dic As Object
Set dic = initDic()
Dim key As Long
For Each dt In txts
Else
lst.Add dt
End If
Next
End Function
As Object
End Function
As Collection
sel.Clear
Exit Function
End If
Dim i As Long
Next
sel.Clear
End Function
Private Function initColorMap() _
As Variant 'array(str)
initColorMap = Array( _
"255, 255, 0", _
"128, 0, 255", _
"0, 0, 255", _
"0, 128, 255", _
"0, 255, 255", _
"0, 255, 0", _
"0, 128, 0", _
"211, 178, 125", _
"255, 128, 0", _
"255, 0, 0", _
"255, 0, 255", _
"128, 64, 64")
End Function
