Mferg318:
Don’t forget that more than half the total weight of the tree was probably still supported by the stump, while it was falling, the full weight didn’t fall out of thin air. Limbs and leaves are bulky, look big, but they don’t weigh much. They do make for good sails in terms of picking up the toppling wind loads. The immediate tree trunk, across an exterior wall, or a few very large (not limber/flexible), and still mostly intact limbs punching through the roof and into a few walls do most of the damage. Unless you have a large limb punched right through the slab or a slab/found. crack immediately under the resting trunk, you probably have a pretty slim case. This is a real difficult problem to put any meaningful numbers on. As PhamENG suggests this problem requires some serious engineering experience and judgement to even start to point a meaningful finger at the falling tree. As the tree first hits the roof, its weight is spread over a large area and is fairly well distributed, vs. the normal roof design loads, thus, kinda breaking the fall. This weight goes down through several rafters/trusses and walls to the slab. If the cracks are new and emanate from one of these loaded walls there may be a case. What do the walls, plates and studs suggest happened, given their condition? You have to be able to point at a couple studs, a post, or some such, which really imparted the slab loading. Are the cracks new or do they have fl. paint in them, or normal living junk, like bread crumbs, fl. sweepings, dog hair, you name it? Normal, random cracks may have been enlarged, but that’s pretty tough to prove. Do they have before and after pictures which show the found. damage didn’t exist prior to the storm? Of course, if the found. damage is severe enough, they could not have lived with that as a preexisting condition. This has to be the kind of logical, well reasoned story you have to weave to bring the Insur. Co. along.
