Adam6
- Dec 15, 2010
- 6
- 0
- 0
Good day,
I have Just confused when i am doing some calculations of forces and moments affecting on the expansion loop,
Pipe Data:
10" X 0.365", API 5L X52
Moment of Inertia: 160.8 in^4
Diff in temp (btw installation and operating) = 165 C = 329 F
Thermal Coefficient = 6.72 x 10^-6 in/in F
Modulus of elasticity = 28.23 x 10^6 PSI
Pipe All length = 920 m, straight line above ground with two anchors at the ends.
So we will have 3 loops with specific dimensions, with supports, and anchors (please find attached)
calculations done by three ways:
(KELLOGG - GRINNELL - CANTILEVER METHOD)
1- Kellogg (Chart C-12)
Fx = 2395 lb
M = 38693.11 Lb.ft
2- ITT Grinnell
Fx = 120.45 lb (its so small, and i consider this force acting on the guide not on the anchor)
as we have (6m span distance) so 24 guides (supports)will be on each side and the acting force on the anchor will be 120.45 X 24 = 2891 lb,, is't TRUE ??!
Sb= 967 Psi ??
3- Cantilever Method:
by dividing pipe into two segments one horizontal (X direction) other is vertical (Y Direction):
Fx = 12 x E x I x Delta / L^3 = 7153.27 lb (this force is the whole force on the vertical leg of loop)
Mx = 6 x E x I x Delta / L^2 = 3576.63 lb.ft
NOTED that
Every method has a value of force and moment,, and the value of cantilever method is very very high comparing with Kellog and Grinell ???
So can any one understand this puzzle and help me, in any way....
sorry for my long POST !!
REGARDS
Pipe Data:
Fx = 2395 lb
M = 38693.11 Lb.ft
2- ITT Grinnell
Sb= 967 Psi ??
NOTED that
REGARDS
