elbulldogio
- Feb 26, 2010
- 7
Hello to you all,
I have been given a problem, consisting of a length of steel pipe of the following dimensions:- 1.75m OD x 3.5m long x 12mm wall amd the pipe is incline at 15 degrees to the horizontal along the longitudinal axis of the pipe. The pipe is to linked into a system using couplings at either end, and I need to calculate the shear forces that these couplings will have to resist. The pipe will be filled completly with static water.
I have worked out the combined mass of this pipe and have assumed that the combined mass acts through the c of g of the pipe which is at intersection of the 3 axes of the pipe. Both couplings must resist the the pipes natural wish to fall to the floor, which would make these couplings supports, S1 and S2.
And at this point I am stuck, I was wondering if some of you kind people with a better education and vast experience can point me in the correct direction. I have been reading books trying to solve this but it all looks like legal language to me. Apologies if you think this is a stupid question.
Please help! Many thanks
