Does anyone have a typical detail that lists the required formwork camber for flat slabs with drop panels (and perhaps also for flat plates)?
I am reviewing a typical detail sheet that we have for formwork camber for flat slabs with drops, giving cambers at critical locations such as mid-panel and mid-span of interior and exterior spans of flat slabs with drops, for 3 sets of spans, viz. 5.8 m to 7.6 m, >7.6 m to 9.0 m, and >9.0 m to 10.7 m. However I do not know how this was developed. Some of the cambers seem suspect because where I would expect a lesser deflection than another location, the specified camber is greater.
I would expect that the camber should equal to the immediate dead load deflection...but I am not sure. Perhaps the dead load deflection should be determined by running SAFE for a number of geometries/loadings.
Or is it the practice to to take a ratio (span/360±?) of the orthogonal spans and diagonal span to determine the cambers, and if so, what would that ratio be?
So to repeat my question, does anyone have a typical detail that lists the required formwork camber for flat slabs with drop panels (and perhaps also for flat plates)? And is there a span ratio should the camber be made equal to?
