SprinklerDesigner2
In a different thread I ran across this:
doitright06 (Mechanical)
23 Mar 08 2:10
Therein lies the problem. Have you represented yourself or your firm to your client as capable to solve or consult on this issue, when clearly, as you have implied, you are not an FPE??
Again, without a qualified FPE involved, you are grasping at straws trying to interpret NFPA 13 for yourself.
A "qualified FPE" is sometimes what I would like to have involved but how to get one without muddying up the works?
I'm certified NICET IV in sprinklers with over 30 years experience on the board or computer and do consider myself qualified in some areas but not others.
I can handle 13R systems, most mercantile as long as it isn't a big box store, office buildings and the like. These are pretty straight forward situations where the design criteria can be taken right out of the NFPA standards.
For some larger projects, Factory Mutual for example, the design criteria is almost always given by an account engineer knowledgeable in the area.
But then there are jobs where I just don't know. The peanut butter warehouse I did last year is a prime example where I got pointed in the right direction. If the product is more then 50% oil then it's to be treated as a class A plastic. I asked, the owner told me content was 55% oil so that one I got right.
What would happen to me if I had designed the warehouse for a Class III commodity and they had a fire that killed someone? Like it or not I did real engineering work I know I shouldn't have done. I don't want to do this anymore.
The idea a designer is a carryover from 30 years ago where all we had was upright and pendent sprinklers on pipe schedule systems on plans that were always reviewed by ISO, FM or IRI. 30 years ago the many states weren't involved in reviewing sprinkler systems we just went and did it.
While I feel I am qualified to lay the system out I oftentimes doubt my qualifications to accurately determine what the proper design should be.
Sometimes I lay awake at night wondering and to tell the truth I don't want that responsibility. I shouldn't have that responsibility, because I don't have the qualifications, but designers take on that responsibility ever day. It's crazy. Sometimes I get scared. If you think about fires, someone getting killed and lawyers you have good reason to be scared.
The Society of Fire Protection Engineers has a white paper dealing with the relationship between the layout technician and fire protection engineer. Many in the installation arena bristle when this paper is mentioned but I think the Society is spot on in this issue.
I think part of the resistence to having a FPE involved stems from dealing with some PE's (not FPE's) and architects in the past. We've all seen things come out of architectural and engineering first that's garbage... for to long that end has shoveled the responsibility over to installation companies.
I don't do design for free and don't expect a FPE to work for free either.
Where I work we're not required to have someone slap a seal on sprinkler drawings. All that's needed is a NICET III or IV signature.
We're a small company doing between $1 and $2 million a year so we can't bring an FPE aboard for full time employment but we need one. I think every installation company needs access to one.
So my questions is for the FPE's that visit.
How do I go about ending the insanity?
Do any you FPE's have a relationship with an installation company and how does that work?
Sorry I got so long winded but the issue really bothers me.
23 Mar 08 2:10
