SKJ25POL
- Mar 4, 2011
- 358
I appreciate if somebody can direct me on some sources ( in simple language) guide me in design of frame around a approximately 10ft (wide) by 12(height) in a metal siding wall.
This opening will be located close to an existing louver(please see attached pic, which I don't know what will be the influence.
I like to know the loads that will be on the door frame and the load path.
If the owner decides to leave the opening open (not installing any door) does the frame see no load?
Also how will be the loads if they use vinyl strips rather than actual overhead door.
I appreciate directing me in this matter.
Respetfully,
Your less experiend colleage.
Respetfully,
