eculver
- Jan 27, 2011
- 10
I came across this forum searching for information about proper french drain construction. After reading much on the subject I am left with still more questions that I was hoping someone out here could give some insight.
First off, I got a detached Garage built over 2 years ago on my property, and I live on a grade. My house and my neighbors house are both positioned higher up on this land, so I get a tremendous amount of water that comes right down to the front corner of this garage. In an attempt to divert the water, I graded as much as possible and made a swale on the side to take the rain runoff to the back. However, I'm noticing significant effervescence in my slab at the control joints, so I figure I have some underground water getting under there. Also, when I was digging a shallow 4 inch deep ditch about 10 feet uphill from the swale to further divert water, I found an underground "stream" most likely due to significant rainfall that season.
My plan is to dig a 2 foot deep "french drain" where my swale is now (about 8-10 feet from the garage) and fill it with geotextile wrapped gravel and smooth pipe. I also want to use this as a surface runoff drain, so I was thinking of covering the gravel top with 10 mil plastic sheeting, and putting river rock on top of that to prevent the large amounts of surface water from getting down in the drain closer to my footing depth (which is 18 inches).
My questions are, would this be a good way to combine drains, or are two separate drains recommended. If so, how far apart? Secondly, my soil is very sandy, probably silt in there too, but little if no clay, is there a recommended AOS for the fabric I should use to lengthen the life of this drain?
Lastly, should I just scrap this whole French Drain idea and create a deeper, wider swale? The underground water I noticed is my dilemma. The surface drain I dug to divert it worked for about a year, but now I think the stream plugged because water accumulates more in the swale now.
By the way, I want to do this as effectively as I can but money is an issue as well, so I'm not looking to get soil testing or any major engineering done. If this works for 10 years I'd be happy
